'81 528i Brake pedal going close to floor
WA6LIE
Salinas, Ca.
Hello All,
My wife was driving our 528i today.
I drove it afterwards and noticed the brake pedal going
close to the floor before braking.
Normally it is about an inch or so of travel before they start to work.
I asked my wife what happened, and she just said it was doing it
going down hill. She said it was intermittent. When I drove it there was
nothing intermittent at all. Just near the floorboard to stop.
It acts as if the lines need bleeding. The brake fluid level is just a bit below
the MAX mark. I pumped the brakes many times, and noticed some action
in the brake reservoir ie.. fluid moving (happened on pumping- once)
Before then, yesterday all was normal.
Any ideas?
Thanks in advance...
Scott
Goldy
7
Alberta
I would think that one section within the master cylinder has failed - or there has been a failure in one of the two zone.
Any fluid loss of large proportions?
If not - then the failure would appear to be within the master cylinder.
EIther way - it is not recommended to drive after any brake malfunction. If the 2nd part of the master cylinder goes - you will have no brakes - except the emrgency /park brake.
Best regards
Goldy
