If the fan isnt kicking in when the engine is getting hot then you will know that your fan clutch is rooted. You can do this by getting the engine up to normal operating temperature and letting it idle for a while with the a/c on. If the fan won't engage and the engine is getting hot then its buggered.
Alternatively, if the fan is not disengaging when the car is just started ie: cold, then it's jammed on and the fan will be cooling the engine when its not needed.
Hope this helps.
