So i just picked up an 84 325e with 290K on it. The deal was too good, couldn't pass it up. The car runs good, but i took it in to try to get the Ca. smog nazis to pass it, and no-go. failed on high hydrocarbons and timing. Timing!?!? Acording to the tech the advance has to be 16 deg. +/- 3. mine is runing at 11.5. So i took it home and checked, sure enough, right around 12 deg. So i did a tune up on it, and threw in a new O2 sensor for the hydrocarbons. I double checked the timing, right where it was. Iim going to try to find an inspection station that wont fail me over 1 degree of timing, but my question is; isn't the timing completely controled by the ECU in this car? Is there a way to advance the base timing to make up that degree? Is there some other sensor that could be retarding the spark? Any ideas would be apreciated. Thanks in advance.
