Some bulbs won't be there if you don't have that feature e.g. ABS brakes etc. The service indicator lights may also be missing. But if you cannot see, anything, you need to replace the backlights which are the ones that shine into the orange perspex part of the dash panel - remove the dozen or so phillips screws that holds the two halves of the panel together to access the inside bulbs - (you want to remove the screws with stars next to themthat sit on little raised circular bits of the panel molding.)
