Ok Gents,
Need help or next suggestion on what the heck is going with this puppy! I don't mind spending the money but I want to get her right again! I'm close, I think.
Heres whats been done; all new parts .... plugs, 02 sensor, idle control value, fuel regulator, ECU, fuel injection gas lines, vacume line from fuel regulator to manifold, cleaned air intake box, air intake boot, checked all possible air intake locations, cleaned throttle springs, cleaned throtle body buttery fly value (most of this was very nasty), sprayed carb cleaner everywhere can't detect any leaks.
Problem: idle surge and check engine light flashing on and off
After ECU was replaced car ran perfect for 30 minutes of idling and 15 or so miles of driving. I drove to the Pentagon this morning and about a mile out of my 18 mile drive, after hitting a bump, the check engine light flashed on again!!!
I pulled into the parking lot and the engine surged again not as high..750 to 1300 PRMs. Same stuff on the way home tonight!
Doesn't do it all the time now, and surging spells are greatly degrated in the amount and time it speeds ilding high!
Engine sounds like she falls, or stutters at highway rpm say 2500 to 3000, but only once and a while. The ECU did help but its still not right! Is there a ground esides the one in the trunk, that one is rock solid! The engine is not throwing any codes...but is running rich on fuel!!! Is there a sensor or idle control sensor I still need to replace???I'm going insane here now....what the hell else can this be! If I was back at an SF Group I'd call in a nine line and blow her in place.......loosing me wits! Likely its something simple. Manual is no help either...I can quote it in places...Whats next???? I've also replaced the Alterator and have a new batter with new terminal conections.
Heck, I've fixed Ducati Race bikes! This is kicking my butt!!!!
Perplexed SF Officer sends!![Confused [confused] [confused]](/images/smilies/confused.png)
