the thermostat looks like an easy fix, i guess i'll just replace it along with the water pump. but i'm not sure if either is faulty. the hoses going attached to the thermostat are all hot when the engine is at operating temp, so i know there is coolant circulating through. would a bad water pump cause the engine to run hotter when idling versus when cruising down the highway? would a thermostat open partially, in which case not allowing enough coolant to circulate?
i drove around and the temp guage read 3/4. i stopped and squeezed the hoses attached to the thermostat a few times then i drove the car again, the temp dropped and ran at 1/2 for a while in stop and go traffic, but eventually climbed back to 3/4 (this is with the a/c on).
sorry for all the questions, but i like to trouble shoot this way before i take a part things and to find out that the parts are good.
thx
