OK so I talked to my mechanic. We talked about my car over heating over the phone. I told him that the fan clutch test with the newspaper worked - it kept spinning. I mentioned that I just drained the radiator, so there isnt and clogging. Also, we talked about the water pump. He told me that the water pump wouldn't be causing my car to over heat. I told him that the auxiliary fan works when ac is on and high temps turn on. Then we talked about a broken head gasket. He said that if I did have one I wouldnt be able to drive it at all (right now i can drive highways fine and not stopngo). SO, then he suggested that i might just have a bad radiator that doesnt do its job, but still holding onto a fan clutch possibility. Well I am here to ask if anyone knows how to check to see if the radiator is in poor shape? I am getting it checked out where i am by a mechanic, and then i'm gonna talk to my one back home that i called and he's gonna help verify a diagnostic, but i wanted to check w/ u guys before as well. Thanks,
Ross
![Pray [pray] [pray]](/images/smilies/icon_smile_pray.gif)
Ross
