Brake lights fleakering...
325ix
22
Ottawa
Brake lights flickering...
Hi guys
when I push my brake pedal, my brake lights are not working or they are flickering, is there anyway to open the switch under the pedal? I felt that is a bit loose, if so is there any DIY website with pictures to show how?
Thanks for the help.
984
Check your switch with a multimeter for full continuity while the switch is closed, if it has resistance, simply replace it, cheap from your local dealer, or scrap yard.
Any switch can be opened, the problem normally is that there, more than likely, is no user serviceable parts inside.
325ix
22
Ottawa
Hi
correct, it was the switch problem, I opened it and took it apart, cleaned it, lubricated and now it works fine, however I barely damaged it. planing on replacing it in spring.
Thanks again
