Hello all,
Weird thing happening in my e30. I recently had the brake pads replaced so I know that they are fine. The Brake Lining Light began to come on intermittenly and now permanently- here is the weird thing. Whenever the light would flash on the radio reception would got out. I'll explain-say I am braking- the light would flash and at the same time and to the same pace as the light there will be static comethrough the radio. Now that the light is permanently on the radio reception is horrible. Sometimes if I hit a bump in the road it will come back in. Bear in mind that there is no problem with playing CD's. Are the Antenna and sesor system somehow connected. Anythoughts on an easy way to fix this.
It's is a 1990 325i incase that matters at all.
thanks
thanks
