My friend has an 1988 E30 325i then needs to have the brake master cylinder replaced. I came over to help him today and we installed the new master cylinder and filled it with new brake fluid yet there's no pressure when applying the brakes. We bleed the front brakes and it works fine but the rear won't bleed for some reason. We tried to pump out all the air out but still not working. Do you think there might be a clog in the lines or are we doing something wrong?
