Carlsturm - DSC = Dynamic Stability control, not skid.
Here's the easiest way of putting it - limited slip is a type of a differential that uses a mechanical way of keeping both wheels moving - not just the one on the slippier surface (or inside in a turn).
Traction control is electronically controlled, bogs down the engine, and applies brakes to the wheel slipping, so THEORETICALLY power will go to the other wheel through the OPEN differential. Some cars have both systems but not many new cars. Limited slip differnetials are expensive.
Limited slip makes your car much more fun. If you want to know if you have a limited slip, jack both rear wheels off the ground, put the car in neutral, take off the ebrake, and spin one of the rear wheels. If the opposite wheel spins in the SAME DIRECTION, it is a limited slip.
The more fun way to check is turn off DSC and all other BS help-me-i-cant-drive electronic systems (..hehe, just kidding), and drop the clutch from 4,000 rpm. If you lay 2 tracks of rubber, you have a limited slip. If only 1 track, then sorry!!!
