Yes there is a good selection of sway bars available. You can check out Ireland Engineering, Bavarian Autosport, BMP Design, Eurasian Autoparts, good prices and West coast location(
www.ea4parts.com). Eibach makes them as well as Suspension Tecniques and several others. They run about $175- $225 depending on brand and size. Most are adjustible. Some people like very thick ones and others do not. On my 1989 325i I ran Eibach ones (20 mm frt and 16mm rear). They matched up well with my H&Rs, Bilsteins, M3 offset control arm bushing and upgrade rear shock mounts. Some cars have had problems with the mounts being torn out and needing reinforcement when heavier sway bars and stock springs are used. Think out and decide on what your entire package will be and then buy.
