Thank you this BMW website and the car owners who had posted under 'wind noise' in the forums. I had a really loud air noise - seemingly coming from the door frame or window. It started at about 40mph and increased over the radio as the speed went up. After numerous trips to the dealer; having the window adjusted? then being sent to their body shop to have the door checked and aligned, I purchased a door molding kit and tried adding to different parts of the car door frame and door. Nothing worked.
I then got smart and found this website, put in the problem and in 10 minutes had the problem solved. The car is whisper quiet. It was the jack bumpers. Mine are on the car, but there was spacing where they were not fitting up tight to the car. I simply pushed them back up tight and put three strips of black racing duct tape around the three edge sides of the plastic bumpers surrounding the jack hole to the car. I even put a square over the hole for good measure. UNBELIEVABLE. Thanks again.
