so,
followed Ferdinand's advice and cut a little off., thanks.
there were oem pre-cut starters, perhaps it was a replacement carpet.
some of the highlights include...
- removing accelerator pedal bottom section from floor, push-in lower tabs, pull upwards and it will release.
- removing accelerator stop peg, very easy, but a must do prior to carpet install.
- also, retrofitted wire harness for heated seat, very easy too, just ran it alone existing window switch harness.
Positive comes from power block to the left of steering column, unique connector to unique receptor,
can't miss, to the left of RD/GR & WH/PL.
negative mates with other grounds in same general area.
no relays involved.
- figuring out wire mesh for extra gauges, hahhaha, i don't label nuthings
- and last but not least, a snaped soft top lid handle, it feel apart, hahahha., good times
have a ton of pics, posting links to them and a few actual images of the mid morning ordeal,
sorry but sun shined hard at times so there's glare towards he end.
Passenger seat out...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3441-med.JPG
Driver seat ...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3442-med.JPG
Rear Seat, bottom only ...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3443-med.JPG
Parking brake console ...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3444-med.JPG
Shifter & extra gauges console...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3445-med.JPG
Rear 1/4 panels ...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3447-med.JPG
Removed carpet, steering wheel and retrofitted heated seat wire harness...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3464-med.JPG
Installed new to me carpet, ran wires and steering wheel...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3474-med.JPG
Rear seat bottom, 1/4 panels and fixed top lid release handle...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3478-med.JPG
Center consoles and gauges as well as heated seat switchs...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3479-med.JPG
Driver seat, rocker paneles etc...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3480-med.JPG
Passenger seat and it's all done ...
http://www.bmwboard.com/gallery/data/2/3107Copy_of_134_3481-med.JPG
now, here's the highlighted events -D
me no like old carpet
new to me carpet, looks better in person, really , notice slice markers...
Heated seat harness, power supply on top left, seat connectors at center and switches to the right
location of power supply for heated seats, top row, empty plug.
Accelerator bottom section off floor as well as stop peg...
Driver side under dash shenanigans, nice
Passenger side looks even better...
Center mambo wambo o
FIN ...
no relays involved.
Driver seat ...
Rear 1/4 panels ...
FIN ...
