fan clutch nut (QUICK QUESTION)
120
Chattanooga, TN
in the process of replacing all the belts and water pump, have really run into a wall... Bentley manual explains it as this:
(170-12)
"1. Place a 32 mm wrench on the fan clutch nut. Strike wrench quickly in a clockwise direction (working from the front of the car) to loosen nut. Spin fan off pump."
now... what exactly is it saying? is there some trick to it?
Nope, no trick. Just stick a 32 mm open-ended wrench on the nut and turn it clockwise (it is reverse-threaded). If your belt will keep the pulley from turning, then you'll be fine. My pulley kept slipping on the belt and turning, so I think I had to have another person help me by applying counter pressure from the other side of the engine using a wrench on one of the bolts that attaches the pulley to the pump.
