break out the multimeter and check to see if there is voltage at the plug first.
If so, clean contacts and get a new bulb. If not, find the relay and check voltage at the source. That will rule out a connection problem.
You NEED to get a Bently Manual!! PERIOD <-not meant to be rude, but its the bmw bible.
let us know what you find
