My '87 325 has some sort of problem in the front end. The steering wheel will shake left and right a little bit between about 55 to 70 mph (the absolute most inconvenient and annoying speeds for the wheel to shake!). Below 55, there is no problem, above 70ish, the shaking goes away. There is also a slight accompanying vibration felt in the car at the same speeds as well - you can see it in the rear view mirror and feel it in the doors and the seat. When I brake lightly to moderately from 70, the steering wheel shake intensifies, but only from about 65 down to 50. Below 50, there is no more steering wheel shake. There is never any sort of pulsation in the pedal, and it doesn't shake the car. It only shakes the wheel. If I apply the brakes moderate to hard from 70 down to 0, the wheel will not shake at all. It doesn't have the symptoms of pulsating the entire car all the way down to a stop like all other warped rotors I've seen - it doesn't pulsate the car at all, just the wheel.
The car pulls to the left slightly. The vibration in the wheel existed before the car started pulling - the car used to track perfectly straight down the interstate without a pull, but the vibration was there even then. So, I'm not sure if the pulling is connected or not. The wheel vibration does seem to generally be getting worse. The puzzling thing, however, is that sometimes the car will drive perfectly smooth at 60, but most of the time the wheel shakes. Most of the time, the car drives smoothly at 70, but occassionally it'll vibrate alot at 70. The intensity of the wheel shake seems to vary, even on my daily commute on the same smooth interstate.
Along with all of this, the front tires are worn on the inside. The inner most tread block is worn significantly more than the rest of the tire, and it appears to have some cupping - the wear is uneven around the circumference of the tire. I think this wear issue is probably related to my wheel vibration. When I bought the car, the guy that inspected it at the BMW shop I took it to said the control arm bushings and ball joints looked fine upon visual inspection. I just took a quick look at the control arm ball joints a few minutes ago, and the boots are all still intact without any grease leakage.
Sorry for the long post, but this wheel vibration is starting to drive me nuts.
Anyone have any ideas?
