Front end Shimmy / vibration SOLVED!
I have a '98 528i. I upgraded the factory rims to 16" and a bit wider off of a 7 series (previous body stock rim) it resulted in a front end vibration at 50 to 70 mph. I have come to understand that offset may be an issue. Shy of replacing the rims again, does anybody have a solution. I have thought about machining the back face of the rim down a bit to move them inward again to compensate for the offset, but there is very little room between the tire and the strut tower as it is (1/4" or so).
I am putting on new tires and will have the front end aligned, but I believe that this will only work short term. I am also considering stiffer bushings from Dinan. Any other thoughts would be appreciated.
