Not every time, but it's happening more and more often, that when I'm accelerating through the higher end of 2nd and 3rd gears the engine makes a bogged-down "waaaa" sound and the engine studders/chokes a bit and loses acceleration power. For lack of a better descriptin, it's kinda like when you are starting a weed-wacker and working the choke between 1/2 and full choke and the engine makes a bogged-down noise until you take the choke off...
It seems like it might be a fuel delivery problem. -and it generally only happens when I drive more aggresively.
Does anyone have any ideas to trouble shoot the problem and what it could be?
I'm thinking maybe the fuel injectors need some work. The fuel filter and pump (inside the tank) were replaced ~1 yr ago.
thanks
thanks
