Fuel pump or relay, e30 died
1,182
Dallas
The other day i was driving my e30 318is around when all of sudden when i pushed on the gas and it wouldnt go. the rpms just kept droping till she stalled, i tryed restarting her and it barly started and instantly stalled then it wouldnt even start again it would just turn. when i turn the car on i cant here the fuel pump turn on at all but i do hear this clicking noise that sounds kind of like the relay what do you guys think
793
Bay Of Islands, NZ
First guess would be fuel pump as you say. You could check the fuel flow, but sounds as if the pump is dead so may be worth replacing it anyway esp. since it happened so suddenly - it is unlikely to be a dirty fuel line or blocked regulator as that would cause gradual problems.
Could be a blocked inlet caused by a largish object, and the sound you are hearing is the pump trying to suck something solid.
Check that first when you go to pull the pump out.
880
Pittsburgh, PA
Take your back seat off and bang on the passenger side metal under the cusion while trying to start the car. See if she fires up. haha I did that for a month until it finally gave up completely and i replaced my pump.
If that doesn't work though take that black panel off and check to see if the pump is getting voltage while the key is in the start position. If it is... find another one at a junk yard. Those puppies are expensive. You can take the motor itself out of the assembly and just solder in a new one too. That saved me some cash.
1,182
Dallas
Thanks alot, I'll pull the pump out when I get home tonight and check the voltages on the plugs. Then I'll get back to you guys.
1,182
Dallas
Alright so i tested the plug for the pump, getting power. So I pulled the pump out I guess im just going to order a whole new one
1,343
New York City
For me it was pulling out main cable from ignition coil, cleaning it a bit, and would start right up, took me 2 months before I had to get a newl coil lol...
1,182
Dallas
Chesty Bonds said:
How much for a new fuel pump in the E30 318is? I'm interested now!
Nadroj, how many kilometres/miles has your baby done?
The oddometer broke about 3 or 4 months ago and it had 155xxx miles on it then
Big Daddy, do you think any of the inside the tank style pump will work on my 318iS, its a 91, because i like 109$ better than 219$ [hihi]
880
Pittsburgh, PA
Unfortunately you most likely have the expensive fuel pump. The newer e30's have only one main pump (no helper). But all you really need is the motor (pump). You can find one at the junk yard for cheap, even if it has the wrong assembly you can take the pump out and solder it in yours. (The junk yard folks can usually do this for you) they did for me.
My 91 318is did not have a "helper pump", and both pumps I listed are in the tank pumps. I would not use a "used" puel pump. You have to have the manufacturer date as they made a mid model change. Mine was the expensive one, and they come as a one piece unit. It is an easy repair, but check the top of the pump for fitment.
