Heater motor
Andover
I turned on my E30 325i convertible today and the heater did not work.
The fuse was blown and everytime i tried replacing the fuse it would simply blow again right away... Im thinking the only way this would happen is if the heater motor was blown, does anyone know how to get to the heater motor or how long this process will take to fix?
984
hello MathhewJames, and welcome to the board.
there are many other resons why your fuse continues to blow, not completly ruling out that your hear blower fan is unservicable, however a short to ground is another likely cause, check all your wiring before atempting to repair or spend a shite load of money to replace the fan itself, to access the fan you need to take of the midle panel on the fire wall in the engine bay, its self explantory under there so good luck. :D
