I HAVE A 1987 325i THAT I JUST SWAPPED ENGINES IN (THE GUY I BOUGHT THE CAR FROM KNOCKED A HOLE IN OIL PAN AND BURNED UP THE BEARINGS/CRANK).
WITH EVERYTHING HOOKED UP, THE ENGINE SPEED JUMPS UP AND DOWN A FEW TIMES UNTIL IT DIES. IF I GIVE IT SOME THROTTLE, THEN I CAN KEEP IT GOING AND IT SEEMS TO SMOOTH OUT FOR THE MOST PART. IT RUNS/DRIVES FINE AT ANYTHING EXCEPT IDLE. HAS A SLIGHT HESITATION SIMILAR TO A BAD ACCELERATOR PUMP ON AN A CARBEURATED VEHICLE.
IF I DISCONNECT THE CONNECTOR FROM THE AIR FLOW METER THEN IT IDLES GREAT, BUT IT IS NOT DRIVEABLE AND BOGS DOWN WHEN YOU TRY TO ACCELERATE.
IT SEEMS LIKE IT COULD BE A VACUUM LEAK. IF SO, WHERE ARE SOME OF THE LIKELY PLACES AND HOW DO I GO ABOUT FINDING IT/THEM???
THANKS SO MUCH FOR YOUR ASSISTANCE!
