I am trying to help my son pull the engine on his 1990 E-30 (with an automatic). He had an encounter with the curb, punctured the oil pan and drove it for a couple of miles. I look at it as a learning experience for him.
We are using the Bentley manual and its not bad, but it has left out some crucial details.
Is it easier to pull the engine/transmission together, or can you separate them at the bell housing?
We have been working under the assumption we can separate them. Our current status is everything has been removed, including the ring gear/torque converter bolts. Is it physically possible to remove the bell housing bolts with the engine/tranny in the car ?
Once out, our plan is to do rings and bearings, I did the valves a year ago.
Any and all help appreciated.
Thanks,
Mark
Thanks,
Mark
