Do you have access to a pressure washer or a steam cleaner?
Heat will dramatically increase cleaning effeciency, as will pressure, both at one time works best.
Heated dust particles from brake pads constantly attack the wheel and bake into the finish. If left on the wheel, a phenomenon known as “galvanic corrosion” sets in which will eventually destroy the wheel’s appearance.
There are 2 types of cleaners, acid and alkaline.
Acid-based cleaners are typically a 2-3% solution of oxylic, phosphoric and/or hydrochloric acid. Most spray-on/hose-off wheel cleaners fall into this group.
While giving the most "punch", tey are also most likely to cause damage if not VERY carefull.
Non-acid or alkaline cleaners usually require some surface agitation (brush or sponge) but are safer to the wheel’s finish.
1. Clean the wheels first before washing the rest of the car. This prevents you from splattering cleaners, dirt and brake dust on already cleaned panels.
2. Do not clean wheels that are still hot from driving. First allow to cool off before wetting with a cleaner.
3. Clean one wheel at a time following the instructions on the cleaner. For extra tough grime and brake dust, agitate the surface with a soft, scrub brush. Do not allow any wheel cleaner to dry on the wheel.
4. Protect the wheels after cleaning to make future washes easier.
A synthetic wax such as Einszett Glanz, Zaino or Klasse will last MUCH longer than a carnuba wax and in easier to use on wheels too!
Hope this helps...
