I have had an ongoing issue with my 1986 e30. The idle is irregular, and a bmw mechanic tried for 4 days to diagnose without real results. The needle just doesn't want to stay put (this is not an SI problem either, since the engine shudders in relation to the needle) I had the idle control valve changed and still nothing. Would anyone out there happen to have the same problem and successfully diagnosed it? My mechanic is now telling me that it's an electrical issue. I had the engine changed a few months back and the problem started after that. I also wonder if having the Turner chip would change anything, thinking the specs were set to the car's original chip.
Secondly I have read and have had problems with my instrument cluster, being this is a common problem. I changed the whole cluster and got the SI board to work but the solder joints seem to not hold up, since the temp guage was on n off and now dead. I used to hit the side of the dash and it would come alive, but no more. I think I need to replace the whole SI board which is about $150.00. I have had no luck with finding a properly working cluster off ebay or otherwise.
Also, has anyone had experience changing out the lock actuator on this car? if so s it easy?
thanks
Sean
![Screwy [screwy] [screwy]](/images/smilies/icon_smile_screwy.gif)
thanks
Sean
