Hello,
Can smb. give me a valuable piece of advice?
I've noticed the problem when it was very cold here in PA.
The car has NO problems starting (cold or warm engine), and NO problems
with idle when the engine has warmed up.
BUT when I start the engine, drive for several hundred feet and then have to stop
at the nearby traffic light for a long enough time (the temp. needle slowly going from the "blue" zone to normal), the revs suddenly start jumping high and low!
Once the engine has even stalled after the RPMs dived below 200 or so.
(I didn't have problems re-starting it.)
The same thing occurs when you start a cold engine (left for at least 6-8 hours)
and leave it warming up in idle mode for several minutes.
- I haven't heard any suspicious noises, and haven't noticed any other problems.
- It doesn't happen when the engine is warm enough right from the start.
- It doesn't happen when the engine is COLD - only during a short period
when it goes from cold to normal.
- The car has got a stick and approx. 50K miles, spark plugs are fine.
Thanks a lot in advance!
