Abdoman said:
Can you list the part you need - how hard is the work? I'm pretty good at mechanical work. I would love to add a little more power!
heres the skinny: the big thing you need, obviously, is an M50 intake manifold. you can find them at junkyards, ebay, classified, etc. i got mine off of the turnermotorsports classifieds. a good price is $125 up to $150. i miraculously found one for $100 including shipping
you need to have some random plumbing and elbows and things. a few custom brackets and a few pita connections. i even used a dremel to cut a hole in the M50 manifold. everyone seems to do the install a bit different. here are links to two install pages:
http://www.midnightautowerks.com/Installs/95intake/install.html
http://www.team-bar.com/main.htm click shadetree diy, then click M50 manifold install at the bottom.
the 528 engine bay is a little different than the M3 in the pictures. i will tell you the cabin filter snorkel barely fits back in. and you have to make a new bracket for the ATF resevoir. there are lots of tricks to the install. if you decide to do it i can give you detailed info about what i did. it took me probably 6 hours of work total.
the gains are felt around 5k and above. the car takes off much better from there and pulls to redline at 6500. there is a minor loss of midrange torque, but with software this is drastically reduced and top end horsepower is increased greatly. with software from eurospeedperformance.com they made 40 whp! and i think it was 20 whp without the software.
any questions?
