You shouldn't need anything different from any other macpherson suspension. The rear is even easier than the front, and the front is a very simple design. You'll need to go to autozone or pepboys and rent spring compressors. Just be careful with them, since those springs are designed to hold 500+ lbs before being compressed. Other than that, a few metric sockets and box end wrenches is pretty much all you need. You should be able to find instructions somewhere, but if you bought yourself a bently manual, it would still make everything easier.
By the way - do you have aftermarket shocks for the springs? You can NOT use stock shocks with lowering springs. It will wear the shocks out in a very short time.
