Instrument cluster:
The mpg fuel economy guage flips out and dances about. The rpm guage also has epileptic seizures. I read that this could be due to broken solder joints in the cluster board or the nicad batteries. What kind of batteries (Nimh) would I need to replace this battery with?
Transmission leak:
About midway down the car there is a leak. I'm taking it in to a mechanic, hoping it's just a gasket replace job, but I read that this car has a problem with that, and to live with the leak, its a leak due to radial movement inherint in this transmission system. I read there are 2 types of oils for this..one is slip the other limited diff... how would i know which mine is?
Starter:
The car sometimes has to churn a few times to start up..and thats at the very end when I'm about to pull the ignition back off. I have already replaced the car battery...what else could it be? the starter motor? a relay?
what year did they stop using carbs and use injectors on the 325's?
thanks
Sean
Transmission leak:
Starter:
thanks
Sean
