This is a 1985 325e w/230K miles. The car has been well maintained, two years ago I replaced the computer with an upgraded unit, also replaced this list of parts: timing belt & water pump, all hoses & belts, both fuel pumps & relays, distributor cap & rotor, plug wires, Airflow sensor box, fuel filter & regulator, all fuel lines, vacuum hoses were replaced. Didn't want any trouble for a while.
Now for the problem. This evening as I tried to start it, had to run starter for about 30 seconds then engine started immidiately. Backed out of drive & pulled into alley behind house to look at fence, backed up and engine died. When trying to start it up, it turns over like there's no spark at all. I messed around with the wire on the starter solinoid, coil wire & crank angle sensor plugs, it started one more time breifly and ran clean but died again like I'd turned the ignition off. Fuel pump runs when turning engine over. No spark seems to be the culprit.
Any suggestions as to what I need to check or replace are more then welcome. I'd hate to replace a crank angle sensor & find out that it wasn't the problem.
![Smile [:)] [:)]](/images/smilies/smile.png)
