Yesterday, I got the message 'low head beam bulb' and sure enough, it's out. Now, which kind of bulb do I need? Can this only be from the dealership or I can order it online somewhere?
Bavarian Auto shows replacement bulbs in their catalog, use gloves but don;t ask me how to replace them, never looked up there. They will send you a catalog once you order something and then you are hooked. Bang!
The bulbs are relatively easy to replace - twist and disconnect the connector with high voltage warning and then remove the protective sleeve and it the bulb comes right out. swap and put everything back in place - the sleeve was bothersome to get off and put back but it took less than 5 mins to do the whole thing on my 02 525. I'm sure it'll be pretty much the same for you
