Okay so here's the rundown: Idle is fluctuating between 5 and 9 hundred RPM on startup only. Rev it a little, drive it a little, no problem. However, if you just let it sit and don't rev or move the car, the "check engine" light comes on. The light also comes on when I go down a hill in a low gear (compression braking). The problem started occuring when my muffler went to hell. That's all the leads I have. I do know that I ripped off my muffler. I replaced my AFM boot (elbow) and cleaned my idle control vavle and TB with intake cleaner. All of my computer leads are connected to where they should be. Nothing is lose and there are no vacuum leaks. When I ran a diagnostics computer on it, the computer says "emission control (lambada)." I have no idea what that means.
I also get this strange rattling noise when I let the clutch out in nuetral. It's quiet, but quite clearly coming from the transmission.
