Hi All...
I need a favor please. If you would please run this little test on your car and let me know what happens. I don't know if it only applies to the e39, the v8's or all BMW's.
On my 2000 540i, with the engine running in "Park", if I step on the accelerator and bring the rpm up slowly, anywhere from idling to under 2000rpm, the engine will kinda "stumble" slightly (like rough idling). I was told by the mechanic that this is normal when the engine is running without load.
Ever since I replaced the Throttle body and the Mass Airflow sensor, the engine runs good and the idling is super smooth without missing a beat. I just find it hard to accept or believe that it is normal for the engine to stumble when running in between idling and 2000rpm without load. I tried this same procedure on my Isuzu Axiom and it runs smooth. I remember doing the same thing to my previous Mazda 626 and it ran smooth.
So...if you all would please try this out on your cars and let me know if they behave the same way, I would be able to sleep better.
Thank you!
Thank you!
