WAIT!!!!! dont rush right out and buy a cone filter! if your car does not run properly when it rains THEN THERE IS SOMETHING WRONG WITH IT! any modification that you make will only do one of two things.........................mask the core problem or make it worse! NEWS FLASH!!!! ................... It rains in germany! this would lead me to believe that the wonderful engineers that designed and refined your amazing BMW automobile "ENGINEERED" it to run in the rain. so guess what that means............. if it is not doing what it was "ENGINEERED" to do then it can only mean one of two things............. A: it was not properly engineered , or B: There is something wrong with it.............. my guess as i alreday said is "B"
now you will probably want to know what to do about it............. inspect any wiring that is low enough or may be prone to getting wet by road splash or any other means, and I mean every inch of every wire, and all of their associated plugs, connectors , terminals and components. bad connections in electrical systems can cause thousands of problems that will masquerade as non electrical problems. also check under the car, under the hood, under and behind the front bumper and rear wheel wells, make sure there are no splash sheilds or body seals missing or damaged that might be allowing water to get where it is not supposed to be. you might also want to make sure that moisture is not entering the car through the ventilation system, both the ventilation system and much of the vehicles wiring share very intimate quarters under the dash.
wait to make ANY modifications until the vehicle runs as it was engineered to, then your hard earned money will enhance or focus your vehicles purpose, not be wasted on masking an overlooked problem.......... i will keep thinking about this problem and do some investigating.............. for now good luck, and for later i will get back to you if only to check on your progress.
dont do this................................................
do this........................................................
and soon you will be doing this..................... [driving2]
happy motoring
