I did it on mine ... not sure exactly how but i'll give you the jist of it ..
when you pull out the instument cluster remove the speedometer and on one of the sides there should be a clear box that covers the gears in that you will want to find out wich gears to remove to get the effect that you desire...I used a small moter from an x-box controler to put 2000mi on mine thats about how much i put on it when on of my gears (the little one) broke...you should also order replacement gears ...at least the small one because that one is designed to break before the others but like mine when it broke some of the peices ground up my other gears ...hope this helps...hoh
Dodgy if doing it for the wrong reasons, PM me and I'll tell you how. Its probably not a good idea to let every man and his dog on the internet know how to roll back miles on cars we as enthusiasts may one day buy.
