New Headlight Bulb's..which ones?
joshp325i
14
Hubbard, Ohio
PIAA makes the best looking bulbs that aren't true HID, the good ones are around $80 for the pair. Be careful if you have plastic housings on your headlamps, some bulbs get so hot they melt through.
129
Southern CA
PIAAs should work fine with your application. Unlike many other aftermarket bulbs, they run at the same wattage as your stock bulb and produce a lot more lumens than your stock bulb, so you don't have to worry about melting your headlamp housing after installation.
