Hello you all.
I had my 325i for 2 months now and would like to ask few questions. I followed this forum for little while and I see that you guys have alot of expertise. I never cared much for BMW since I always prefered SUV for my driving needs. I got this car as solution to long distance commuting 116 miles one way. It is in very good conditions as far as engine performace goes but had some items that needed to be replaced. I got new top for it and also changed leather on back seats. I covered front seats with sheep skin covers for now. After driving it I really like the car and the way it drives. I see what I was missing. There are some electrical issues that I will have to solve some way and that is something I would like to ask you expertss about. My rev indicator is not working. I checked all fuses in the box under the hood and all of them are good. Is there anything else I should check? Also even that I am reading 12 volts on interior dome light fixture I can not get light to work. I replaced boulb, cleaned contacts but no luck. There is ocasionaly some poping noise comming from what I believe is cruise controll trottle control unit located on left front fender under the hood. It usualy stops if I engage brake or clutch. After little while it stops. I am not using cruise control since transmision is manual and I don't thing it even works. How can I disable it? Engine is 6 cylinder, with manual transmision. It has 146 000 miles and it is not using any oil. How many more miles can I expect to get from it? I replace oil and filter reliegiously after less than 3000 miles. I would like to find good source for quality rebuilt engine. I would appreciate your advice for good and reliable source for engine. I saw some on net and there are few options as performance type engines atc. It is worth to go for performance type engine or it is just gimmick? Thank you in advance for your advice.
Kosinar
Kosinar
