New to this forum.
I own a 1990 535i.
just recently it started overheating. I took out the thermostat and tested it and seems to be working fine. I noticed that the top hose coming from the thermostat turns hot when idling while the bottom hose going to the thermostat is cold as if there is no coolant flow. could my water pump be the reason? how can I tell if water pump has failed? there is no coolant leak that I can see.
any advice will be greatly appreciated.
I own a 1990 535i.
