1987 325, both windows suddenly quit working at the same time--Assuming it is probably a fuse since the problem is with both windows rather than just one, I got a printout from my mechanic showing the fuse layout, replaced the 30amp fuse in the the fuse box under the hood but it didn't fix the problem.  The grid I have shows that there is also a 25 amp circuit breaker associated with the power windows, but I can't find on my diagram or in the car where a circuit breaker goes.  My regular mechanic doesn't know where it is.  Is it in the console where the power window buttons are?  Behind the dash somewhere?   HELP!
