Pulling hard to the left
UK
Allan Day
My immediate response would be to look at the brakes on the RIGHT of the car, maybe not a lot is happening in that department. Hope it helps.
JUS
Member
100
SAN ANTONIO, TEXAS
Check for the following five items listed below
1. worn, defective damaged or contamited brake pads on the right side.
2. Seized or partially seized front brake / caliper /wheel cylinder piston.
3. A mixture of brakes pad / lining materials.
4. Brake capliper or backing plate mounting bolts loose.
5. Worn or damaged steering or suspension components.
GOOD LUCK
JUS
