I didnt have to pull my radiator. This is how I replaced my water pump, which is the same thing to remove to get to the belt. I drain my radiator, took off the crank sensor, loosened and removed fan. Then remove every hose except the lower one on the driver side. Removed the AFM. You don't have to but it takes 5 minutes and gives you a ton of room. After that I took off the alternator belt and fan shroud. Then I removed the water pump pulley. Since the pulley rotates when you wrench it, use an air ratchet if you have one. It wont spin because your torque is in the center of the socket. If not then use a strap wrench. You have to remove the cap and rotor, but don't unplug it. Just move it out of the way. Remove 2 bolts that are in the head that hold on the timing belt cover. Loosen the alternator bracket bolt that is the 3rd bolt on the cover. Remove the top 2 bolts on the water pump but keep the bottom 3rd in but loose. Rotate the pump down a little and remove the tensioner spring as best you can. I don't even know why its there. I was told not to loosen the tensioner pivot bolt. Remove the water pump. Now you should follow the rest of the steps to remove the timing belt which I havent done yet.
