Removing/replacing fan clutch
32
Morgan Hill, CA
Some or you may know that my car is overheating and not currently working. I have my fan clutch and water wetter and want to get it working again. Does anyone know how to remove/replace the fan cluth? The chilton book i have just says to remove the air box then hold the water pump up remove the fan clutch that way by unfastening it with a 32mm wrench. Ok thanx.
880
Pittsburgh, PA
you shouldn't need to take out the air box. The fan clutch is reverse threaded so you have to loosen it the wrong way. I used an adjustable wrench and hit the wrench with a rubber mallet. (The only way to get it off is to juke it off. did i make up that word? You know what i mean?) I couldn't get it off for a while, almost gave up, then smacked the wrench as hard as i could one last time and it came loose. Spray it with PB blast, maybe that would help. You may have to take off the radiator shroud. I think i had to.
174
Oregon
I had to resort to using a thin metal punch and a hammer to get mine loose. Just a couple of taps and it was loose. Didnt even hurt the sides of the nut. Who cares though if you are replacing it. I could not get any of my adjustable end wrenches to fit in there.
