Waterspots on Windows
Membim:
I tried straight vinegar...no luck...I previously tried all the cleaner, & wax removers I could think of....even chemicals like acetone, Xylene, Goof off and Lacquer Thinner. None of these methods resulted in any noticable improvement.....
I was out of conventional ideas and starting to consider very dangerous tactics such as using a dremel tool/polishing wheel when VLAD came up with the recommendation of Einszett Glaspolish which arrived Friday. (Ordered from Detailers Paradise)
I tried it last night in the garage on a small area by hand.
The results are very encouraging. I will try it with a buffer later today outside so i can see the true results.
I also bought an array of other products VLAD suggested and will be trying those out today as well.
Being of Irish descent...I Like the potato idea...if it don't work, at least I can eat it. Irish stew anyone!
More to follow...
Carl
