I've got Bridgestone Turanzas, 205/55R16 on my car. I'm pleased with the ride, not harsh at all; I suspect these tires don't handle as well as some of the other options listed above. Runflats seemed like a great idea at the outset - able to drive from 30 to 100 miles depending on the load in the car after the tire monitor system identifies a low tire. So, I pick up a self tapping screw after 2 weeks of ownership. I think, no problem, top it up every day, get fixed at end of week when I have more time. However, the dealership doesn't recommend fixing the tire. That means buy a new tire every time I get a flat?! No way! The tire dealer said they can look at it and determine if the casing is OK. It is, patch it and I'm on my way. But what happens when I'm in bumflat nowhere Nevada and have no choice but to drive in a low pressure condition until the tire is ruined. Now I'm out 200 bucks instead of 20 for repair. I'm thinking of the above listed options as soon as I burn this set out. Two questions:
1. Is the suspension tuned specifically for runflats? and would the changeover be less than optimum?
2. Should runflats be rotated? again the dealership says don't rotate.
