Resetting "inspection" code dash indicator
greybeard
Virginia
1987 325i. The "inspection" indicator that counts down from green to yellow and then red is now yellow and red. The garage I took it to for a reset said they didn't have a tool for a car that old, but the guy said I could reset it myself by grounding pin 7. Said to take a wire, stick it in pin 7, then ground it to the chassis. Then start the engine, let it run for about 10 seconds and it will reset.
I'm a little afraid to try it. Will this work??
1,303
Charleston, SC
yeah, be afraid until you find out exactly what you need to do. you can fry your computer.
its all over the net, pretty sure here even. just do a quick search. (sorry, but i dont want to say and you screw up your car)
402
Washington State
I heard that you were supposed to short two pins, not just ground one of them. I know the post is in the archives somewhere. When I tried grounding the pins it didn't work, but my nextdoor neighbor has the reset tool that the mechanics use. Just be careful - if you're not sure, it's probably worthwhile to take it elsewhere to find the right equipment for the job. Best of luck.
104
netcong nj
yes if its a 20 pin round turn key on pin 7 and ground with a test lt you might have to disconnect test lt a few times and reconnect it to get it reset
