Right turn accelerate.......rattle
25
Malaysia
Recently,i noticed that when i make a right turn and accelerate I can hear a rattle noise coming from under the rear of my E30.
It only happens when I make sudden/sharp right turn under acceleration......no problem with left turn or straight accleration.
Whats wrong?
Thanks.
175
Topsfield MA (N of Boston)
bet cha 100 bucks that it's the exact same problem i had with my car... and NO ONE knew what it was
does it happen only between 2 and 3.5k rpm? (well, in an eta at least... so probably around 3.5-5 in an 'i')
let off the gas it goes away, right?
100 bucks (well not really[^] ) says it's your catalytic converter HEAT SHEILD rattling... that's what it was on my car... and i swear it took me 3 months of off & on searching to find out what it was [?|] [?|] [?|]
if you grab it & it floats around a little, just yank it the fack outta there. if u need to lower your exhaust a little to get it out, remove the bracket that holds the exhaust to the rear of the trannie or something to loosten the exhuast up a little bit & drop it down... if u need to drop the exhaust down a little more, remove whatever else u can
don't worry bout the heat sheild not being there, there's another one that's attached to the bottom of the chassis & i haven't noticed a single thing that's different after i removed mine
(now i just have to get a new bracket to hold up the exhaust since i snapped the friggin bolt where it attaches to the exhaust & can't get it out for the life of me [mad] )
good luck, lemme know how it goes [thumb]
