I own a 2000 Z3 m-roadster.Its a great car.But, the black fabric lining under the hood sags a little.It rests on the front of the valve cover, leaving a black mark on it. Also where the throttle linkage is ,two little holes are poked in the lining.I don't know if the situation is hurting anything but I want to try and fix it.I have removed the lining .It looks like if I put some good double face heat resistant tape on the under side of the hood it may hold the liner up.Or I was thinking about velcro.
Or maybe even reshaping the liner and painting the side that goes against the hood with fiberglass or something so it holds its shape.Does anyone know the rite way or a good way to take care of the problem? Thanks,Ronald
