I know this has been covered a thousand times on a thousand forums, but with my 89' 325i, should I go to synthetic oils when she's got 200k+ miles... She runs just fine but would like to prolong the life of her if I can. I have an oil leak at the oil filter housing bracket on the engine, going to replace that seal and that will end any engine oil leaks, then will have to change the oil. Should I go Syn? Let me know your thoughts, and what type of oil would be best in a warmer climate that rarely gets below freezing but can get hotter that 100f... Any tricks you know of to get the oil filter housing off the engine block?? It's leaking at the block.
