Had my tires balanced today, they are a set of (275/30/19 rear) (245/35/19 front) . The guy remove the hub ring or center ring, because it was all pressed againt the hub. Now he said it should ride okay, problem is it rides like garbage. Do I need the center hub ring for these rims to have the balance okay? The car had a slight shake between 50-60mph and then it would taper off. thats why I took it to have a tire balance. Now I can't get past 45mph the wheels feel like they are about to come off. The tire guy order the hub rings though and said if that don't work, it's the wrong tire application ! Is tihis possible,( 95 540i with 106,xxx miles)
