hey guys....2003 M3 with the standard tires.....whats the recommended cold tire pressure for front and back? called the BMW help line and the guy searched for 10 mins..took my number and said he would call me back...hasnt yet.
look for a black sticker inside the drivers door jam. one will have VIN and stuff, other will have tire pressures.
well ill just go look on my dads car. ok for the 18'' rims, 41psi-front/48psi-back.
ok...i just checked my door....i see where you see the 41/48 pressures...but below that on the chart is a 33/35 as well.....is the 41/48 if u have a massive load in the car....and the 33/35 for most of the time..with up to 4 people in the car?
The lower numbers are when you have just yourself and a passenger. The other numbers are for when you load the car up and have stuff in the back. The sticker in the door states unloaded and loaded or words to that effect. Just run with the lower numbers.
